show twamp endpoint
show twamp endpoint {ipaddress ip {port udp_port}}
Description
This command displays the endpoint configured values, run-time data, and test session information.
Syntax Description
ipaddress The endpoint IP address, either IPv4 or IPv6.
ip Specifies the endpoint IP address.
port Specifies the endpoint port.
udp-port The UDP port the endpoint will listen on; range is 1025 – 65535.
Default
N/A.
Usage Guidelines
None.
# show twamp endpoint ipaddress 19.1.1.100 port 5000
 TWAMP Endpoint
    Endpoint Information
      Local Address:              19.1.1.100  Listening Port:                 5000
      Received Packets:                 7948  Transmitted Packets:            7948
      Active Sessions:                     5
    Session created on Thu Nov 13 15:41:49 2014
      Peer Address:                 19.1.1.2  Port:                          11001
      Sequence Number:                  1575  Last recv'd packet:             84ms
      Peer Address:                 19.1.1.2  Port:                          11002
      Sequence Number:                  1555  Last recv'd packet:              16ms
This command was first available in ExtremeXOS 16.1.
Platform Availability
